1st Build - Black Walnut/Spruce OM http://www-.luthiersforum.com/forum/viewtopic.php?f=10130&t=44431 |
Author: | eigenwood [ Tue Oct 28, 2014 12:38 am ] |
Post subject: | 1st Build - Black Walnut/Spruce OM |
This is a restart of my build thread for the local woods challenge. It has taken a while to build forms and things so I've really only kicked off the actual building part over the past couple of weeks (mid-October). |
Author: | eigenwood [ Tue Oct 28, 2014 12:39 am ] |
Post subject: | Re: 1st Build - Black Walnut/Spruce OM |
Molds, Dishes, Tools, Templates It took me a while to make the radius dishes. I used a long compass to draw the curves on a template, then used the template to make rails that I ran my router along as I spun double-layered MDF around a center point. Worked okay. It was messy, but doing it outside helped reduce the nastiness. [ ![]() After looking at the prices of deep-throat gauges ![]() ![]() I made a shooting board not pictured. The white mold pictured in a photo below is borrowed from my dad. I initially decided to try to follow the free http://www.grellier.fr OM plans. This meant I'd have to build another mold, but after looking at my dad's, I decided to just roll with it. There is some variation in the waist (marked in red over the grellier plans), but the rest of it is very close. I think the mold is built off a template he got from his luthier buddy. ![]() If I get around to taking photos of my tools, I'll post them here. UPDATE (4/15/2015): The mold that I referred to before didn't work. It was too tall, and I didn't want to mod a mold that wasn't mine. So I made one. Looking back, it wasn't that difficult and was definitely worth it. Some things I included in this mold was shorter sides, more relevant outside angles for clamping, latches for opening the mold, and dowel for registers to make the mold seat accurately. ![]() It seems to work well. I kinda wish I had a taller one as well. ![]() I also made a go-bar deck using some plywood and threaded rod. I used a junk oak board that was warped for the clamping rods, and the natural curve in them seems to lend itself to easy bending. The oak is a little hard and leaves little imprints in the spruce, but that is easily sanded out. ![]() Update (4/21/2015) Binding tools seem to be quite an industry, and I'm sure I'm about to find out why as I start the binding process. I looked at lmi's gramil and decided to try out an alternative before I went down that route. Here's a circle cutter for a drill press converted in to a purfling cutter. I just epoxied a drill bit in to a section of dowel for a less abrasive register. The great thing about this is that I can switch it back to normal by putting in the old bit, or add on a different register I want to cut rosettes by hand. ![]() |
Author: | Rod True [ Fri Oct 31, 2014 12:09 pm ] |
Looking good so far Zach. You'll be fine with 0.070" at the waist but make sure you don't over sand after you get the binding in and prior to finishing. Mark in pencil on the side that is thinner "DON'T OVER SAND" or something like that. It will remind you ![]() |
Author: | Jimmyjames [ Thu Apr 09, 2015 10:27 pm ] |
Will you tell me the scale length of the Grellier plan please? I could assume 25.34 but we all know about assumption. Thanks, -j |
Author: | cphanna [ Thu Apr 09, 2015 11:37 pm ] |
That all looks pretty cool to me. You wouldn't believe some of the jigs and fixtures I've cobbled up for one time use....that wind up getting used again and again. Regarding your thickness caliper: Just sand that hardwood "anvil" to a gentle, rounded curve on top. No big problem there. |
Author: | Cablepuller [ Sat Apr 11, 2015 4:45 pm ] |
eigenwood wrote: This is a restart of my build thread for the local woods challenge. It has taken a while to build forms and things so I've really only kicked off the actual building part over the past couple of weeks (mid-October). Hi eigenwood Will be watching your project with interest. . I am also starting a grelier om from scratch. . My first scratch build so should be challenging (already is !!) Might take me a while to do though.. hope yours goes well and keep posting progress photos please Cheers ![]() |
Author: | SteveSmith [ Mon Apr 20, 2015 2:08 pm ] |
Nice work. Looking at the sound port I'm thinking this is a left-handed guitar? |
Author: | eigenwood [ Mon Apr 20, 2015 3:31 pm ] |
Thanks Steve! Yep, it's gonna be a lefty. I'm actually right-hand dominant, but did some damage on my left hand when I was young that makes it tough to play right-handed. |
Author: | eigenwood [ Sat Apr 25, 2015 2:04 am ] |
Binding I was hoping to be done with binding by now, but... I attempted to hand cut binding/purfling channels with my circle cutter/purfling cutter and a chisel. I was about three days and a nice case of early-onset arthritis in to the channels when my chisel blew through the back. It cracked up a flap about two inches wide. I put some ca glue on it, then clamped it back down, sanded, and it doesn't see too noticeable. Looking back on the incident, I think was exercising a reasonable about of hand tool skill the first day, but it got progressively sloppier as time went on. A lot this was just hand cramping/fatigue, but also frustration at cutting across the grain of black walnut. I sharpened the cutter head to 2000 grit, but it didn't change much. I tried edging in on the final shelf, starting narrow, then getting wider as I removed material. Not a big difference. I even cut off a piece of a retired block plane blade and ground a narrower angle (20 degrees) thinking that the steep angle (45ish) on the circle cutter might be the issue. It was still ridiculously difficult for me to cut. So, I'll be ordering a router bit set from stewmac sometime in the next couple of days. I have a laminate trimmmer, but will probably need to devise a jig to hold the thing. I like the simplicity of a parallelogram or drawer slide for vertical motion, and a mount board for moving the guitar in to the bit. |
Author: | DennisK [ Sat Apr 25, 2015 6:32 am ] |
When cutting channels by hand, first focus on getting through the plate. Score, chisel, score, chisel, until you're down to the sides/linings. Then you don't have any changing grain direction messing with you while you clear away the side material. Carefully chiseling away side/lining material and squaring up the channel is the time consuming part for me, and is indeed pretty hard on the fingers. Probably says something that I've gotten too lazy to do back binding on my last several instruments ![]() |
Author: | eigenwood [ Wed Aug 12, 2015 1:58 pm ] |
Finished in June. ![]() ![]() ![]() |
Author: | eigenwood [ Sat Jan 26, 2019 7:33 pm ] |
Now that I've had this thing for about 3 1/2 years, here's my longer-term feelings about the design choices I made: I'm really happy with: #1: Walnut back and sides. I thought I might regret not using EIR. But I don't. It has great tone, and I like to be able to tell people where it came from. I feel connected to my dad when I play it. #2: The arm bevel. I like this a lot. Especially after playing other instruments. It probably wouldn't be perfect on every guitar, but no regrets there. A few things I would do differently: #1: Ditch the assymetrical fretboard extension without actually adding an extra fret. I think I thought it looked cool at the time, but looking back on it, it just seems a little odd. #2: I wouldn't have done the soundport. I'm still up in the air about the difference in sound. From my personal tests, it lets a lot of the sparkle/airiness of the treble hit the player, but it also loses a bit of punch. At least that is my theory. And maybe this is really where I am at with the soundport. Sometimes I like it, and sometimes it is like a have a big hole in my guitar. ![]() #3: Less complicated binding. Maybe just ebony, and no other strips. The biggest mistakes you can see on the finished product are where I botched up the maple/bloodwood/maple trim on the side. And the maple/ebony trim on the top ends up making the maple look a little dirty. For someone tackling their first binding, I would tell myself to just use a single piece of binding. Probably what I will do next build. #4: Keep the top thicker/ I think when I was in the middle of the build, I was correlating thin top with responsive top. That was probably a mistake, and the result was that the guitar has a harder time with keeping up with chord strumming, or heavier attack. At least that is my theory of what I'm hearing. When I look back on this build, I think what I ended up with was a good-sounding instrument. Maybe not great-sounding, but better than I expected when I first starting dreaming a build. |
